Reply
AC1750 R6400 for wifi via Verizon FIOS router/modem
jhw59
Follower
My current wifi speed is very slow via my Verizon FIOS router  so I thought I would use this netgear for better wifi speed. Is there a easy to understand guide to help me do this correctly? Thanks!  Windows 10
AC 1750 R6400 Nighthawk   (not listed on dropdown)
Model: R6700|Nighthawk AC1750 Smart WiFi Router
Message 1 of 3
Re: AC1750 R6400 for wifi via Verizon FIOS router/modem
Because you posted in the Nighthawk section. The R6400 is not a Nighthawk device.
Try here:
General WiFi Routers (Non-Nighthawk) - NETGEAR Communities
Not sure what you want to know.
There is support for the R6400, including a manual, somewhere at the end of this link:
>>> R6400 | Product | Support | NETGEAR <<<
You could try reading the Quick Start guide.
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 2 of 3
antinode
Guru
> Try here: [...]
   Did you?  And what did you find there?  No doubt, what you intended
to recommend was the now-dead/locked "R6000 Series AC WiFi Routers"
forum:
      https://community.netgear.com/t5/x/bd-p/home-wifi-routers-r6000-series
   See also:
      https://community.netgear.com/t5/x/x/m-p/1667522
From the dates, you can see how important this must be to the Netgear
forum manager(s).
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1336 views
  • 0 kudos
  • 3 in conversation
Announcements
