- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
AC1750 R6400v2 firmware update does not have exe file in download
- Mark as New
- Bookmark
- Subscribe
- Permalink
I went to this website to download the latest firmware update. The download has a release notes file and a .chk file. I am using a Mac. Where can I get the exe file to execute? I would just use routerlogin.net but I forgot my security responses. AC1750 R6400v2
https://www.netgear.com/support/product/R6400v2.aspx#Firmware%20Version%201.0.4.106
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: AC1750 R6400v2 firmware update does not have exe file in download
You don't execute the file. You upload it to the router following the manual update process.
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
- Mark as New
- Bookmark
- Subscribe
- Permalink
ahh but it needs my router admin login info which I do not have nor do I remember my security questions and since the item was purchased awhile ago, I no longer have support.
- Mark as New
- Bookmark
- Subscribe
- Permalink
If you don't know the login and didn't setup (or don't know) the security questions, then you'd need to factory reset to get back to the defaults
Push and hold reset for 7-15 seconds while its powered on.
Then reinstall the router.
default login: admin
default password: password
