Reply
AC1750 R6700 install problem
jetawaydr
Follower
trying unsuccessfully to switch out my old Netgear router with a new AC1750 R6700. I went through 1,000 tries both with nighthawk app and at routerlogin.net. I keep getting the error message " unable to detect an internet connection", while the Netgear 42 & 42-5 are showing up as available.
Message 1 of 2
SgtJake916
Re: AC1750 R6700 install problem
Was there any resoulation to your issue? I just got an AC1750 R7600v3 and out of the box I get the samething.
Yes,my internet works.
Also replacing an old Netgear. I reset the router and tried again. After the 3rd attempt it finally connected. I checked and there was a firmware update so installed that. Upon reboot the  router connected, so thought it was fixed, but after rebooted after just changing the SSIDs same issue.
So odd as the WAN light is green and I can see the router connected to the cable modem.
Any suggestions?
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 287 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
