Orbi WiFi 7 RBE973
Reply
AC1750 R6700v2 indicator lights don't work right?
tangomango
Hello Friends,
I connected two external devices via ethernet cable to my ports 3 and 4 (a TV and a Roku player). Both devices seem to pull decent speeds, no delays noticed right now, but the lights on the router are orange/amber and not white. Why is that happening?
Thanks for your help.
Model: R6700v2|Nighthawk AC1750 Smart WiFi Router
Message 1 of 5
Accepted Solutions
antinode
Guru
Re: AC1750 R6700v2 indicator lights don't work right?
> [...] the lights on the router are orange/amber and not white. Why is
> that happening?
   Perhaps for the reason explained in the documentation.  Visit
http://netgear.com/support , put in your model number, and look for
Documentation.  Get the User Manual.  Look for "LED and button
descriptions".
      The LED color indicates the speed: white for Gigabit Ethernet
      connections and amber for 100 Mbps or 10 Mbps Ethernet
      connections.
   Additional reading might be beneficial, too.
Message 2 of 5
All Replies
antinode
Guru
> that happening?
descriptions".
      connections.
Message 2 of 5
tangomango
Thank you! This resolves it.
Message 3 of 5
antinode
Guru
   You can get the same effect on one port from a device with a gigabit
interface when it's in a stand-by (sleep, "off", ...) mode.  A typical
gigabit Ethernet interface in stand-by mode will run at a sub-gigabit
speed (using less power).  When the device turns active, it will
negotiate a higher (gigabit) speed.
Message 4 of 5
tangomango
I have a sub 100Mbps speed running 24/7 so it makes sense that the lights would be amber and not white! I assumed something was wrong, but everything is all righth.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 973 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
