Reply
schliesndice
Follower
AC1750 network not showing up
Hey guys,
I recently purchased the Nighthawk AC1750 router and the Netgear CM700 modem and I have been having a lot of problems getting them set up. After getting help from my ISP(Xfinity) I was able to get internet working, I can get online using an ethernet connection from my laptop to my modem. But when I connect the modem to the router, only the power light and the internet light are lighting up. Before the internet worked the router seemed to be fine, everything was lit up and I could successfully connect to the network, there was just no internet. Now I can’t connect to the network at all, it doesn’t show up on any of my devices. What can I do to get the router working? Thanks in advance.
Model: R6700|Nighthawk AC1750 Smart WiFi Router
Message 1 of 2
DarrenM
NETGEAR Moderator
Re: AC1750 network not showing up
You may what to try mac cloning to see if that works for you.
https://kb.netgear.com/1086/No-Internet-with-new-router-MAC-spoofing
DarrenM
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 824 views
  • 0 kudos
  • 2 in conversation
Announcements
