Reply
AC1900 Model R6900P Renaming wired ports
JohnHerrmann
Follower
I just set up my new router using the NetGear app and renamed the WiFi network; however, when I connected to one of the four wired ports, I see the default name that was associated with the router out of the box.
How do I change the name associated with the wired ports?  What tool should i be using?  Can this be done through the app or does it need to be done by logging into the router?
Model: R6900P|Nighthawk AC1900 Smart WiFi Dual Band Gigabit Router
Message 1 of 2
Guru
Re: AC1900 Model R6900P Renaming wired ports
Its not a function of the router. Its a function of windows.
You can change it in windows if you feel comfortable modifying your registry.
https://www.howtogeek.com/364291/how-to-change-or-rename-the-active-network-profile-name-in-windows-...
Danger, here be dragons when playing with the registry.
Current Setup: CM2000-> RBK750-> GS716v2-> RAXE500-> Pi-hole->
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 92 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
