Reply
AC1900 Nighthawk
GrillMaster
AC1900 Nighthawk
Need 20 more ports . the switches i have been looking at are Netgear JGS524E-200NAS & GS724T-400NAS . I'm choosing to hard wire everthing from wireless , but still using the AC1900 for ipads . Have 2 .More info this also for a Home Network.
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 1 of 5
William10a
Master
Re: AC1900 Nighthawk
The JGS524Ev2 is the gb port version of JGS524E which is 10/100 mb 24 port switch.
The GST724 is a smart switch gb which it can set up the control the each lan port via software on the switch it's self and comes with a few different features depending the exact model you get..
The JGS524Ev2 should just fine unless you full control over each port of the network.
Message 2 of 5
GrillMaster
Which one should i use as the master switch , off the AC1900 or JGS524 & does it have the Same Safety firewall
Message 3 of 5
netwrks
Master
The firewall is on the router, not on the switch. Don't daisy chain switches. Plug each switch on a LAN port on the router.
Message 4 of 5
That's an interresting case, by the way when you google translate daisy chain from ENG to FR that is really funny!!!
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 2841 views
  • 1 kudo
  • 4 in conversation
Announcements
Orbi WiFi 6E
