Reply
Follower
AC1900 R6900P 5ghz wont show
Some weeks ago my 5ghz just dissapeared, I had it as a hidden network. Ive tried to unplug and plug, and factory reset. The 5ghz light has lit up all along but the network wont show even when i enabled SSID broadcasting and after factory resetting. It too doesnt seem to work when i enable smart connect as i only get 80 mbps of the 200 that I used to get with 5ghz and still get with ethernet. Please help Smiley Sad
Model: R6900P|Nighthawk AC1900 Smart WiFi Dual Band Gigabit Router
Message 1 of 2
NETGEAR Moderator
Re: AC1900 R6900P 5ghz wont show
Hello Luis2l
You may want to contact support about this if the router is still under warranty.
https://www.netgear.com/support/contact.aspx
DarrenM
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 214 views
  • 0 kudos
  • 2 in conversation
Announcements
