whib96's avatar
whib96
AC1900 R7000 IP configuration invalid issue on multiple devices
Newest firmware.  Connected to a cable modem.  Connected an iPhone and an Xbox and then every other device cannot get a valid IP configuration including phones, Macs, and Windows computers.
I reset the router to no avail.  After resetting the modem, another laptop got connected.  But now, the Xbox will not connect.  It seems that only two devices are connecting at a time.  What can I do to solve this problem?
  • Figured it out.  My modem was just a gateway, not a router/gateway.  The router was by default in AP mode, and I had to set it to router mode.
  • Check the lan settings and make sure its capable of giving out more than 2 IP addresses ?
    • whib96's avatar
      whib96
      The LAN setup is grayed out in my settings.  I cannot get into it.  Why would this be?
      • whib96's avatar
        whib96
