ben2bad
Jan 02, 2020Aspirant
AC1900 WiFi Router Model R6900 QOS setup different from manual
I have an AC1900 model R6900 wifi router and I'm trying to set the QOS settings for better streaming video but what I'm reading in the manual I don't see in the actual modem setup. If I log into setup click Advanced> setup> QOS setup> I'm according to the manual supposed to see a DOWNSTREAM QOS check box, all I see are two tabs one is QOS tab which has enable QOS the other is a WMM WiFi Multi Media Tab to enable WMM for 2.4Gh and a 5.0Gh why is this happening at first I was using the manual for the R7000 now I have the correct manual but still have a problem
Netgear updated the firmware on that device for dynamic qos settings. I'm not sure which version did it and they must not have updated the manual if you're still seeing the old style
https://kb.netgear.com/25598/How-do-I-configure-the-Dynamic-QoS-feature-on-my-Nighthawk-router
1 Reply
