Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
AC1900 grayed out internet, LAn, Wan setting under advanced steup
- Mark as New
- Bookmark
- Subscribe
- Permalink
2017-11-18
12:23 PM
2017-11-18
12:23 PM
On PC have both lan and wifi. Connected to router via wifi , wwwrouterlogin.net. Got to advanced after loging in, went to setup. Dropdown shoes Internet, WAN and LAN grayed. Can not activate them. NOTE: I previously set the base IP address for wifi ip address connection to 192.168.2.2 to seperate lan/wan from wifi. Hard reset with button on back of router did not chane that back? Any suggestions?
Solved! Go to Solution.
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 1 of 3
Labels:
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
2017-11-18
03:57 PM
2017-11-18
03:57 PM
It sounds like your router is in AP mode. Try doing a factory reset through the settings: ADVANCED > Administration > Backup Settings > Erase.
Message 2 of 3
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
2017-11-18
03:57 PM
2017-11-18
03:57 PM
Message 2 of 3
- Mark as New
- Bookmark
- Subscribe
- Permalink
2017-11-18
06:04 PM
2017-11-18
06:04 PM
Re: AC1900 grayed out internet, LAn, Wan setting under advanced steup
I tried a reset before but must not have pressed long enough or hard enough. Your solution solved.
Thank you!
Thank you!
Message 3 of 3
Announcements
