Reply
AC1900
cohenortho
Follower
AC1900
I am trying to access the area of the Netgear site to update the firmware on my router. When I  respond to the security questions, I am told that the answers are incorrect. I guess I do not know what school I went to or my sisters name. There is no way around this and I cannot go further.  As ususal Netgear has no help available to resolve this issue.
Any Ideas?
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 1 of 3
antinode
Guru
Re: AC1900
> firmware on my router. [...]
   I'll assume that "the Netgear site" means your own router's web site
(something like "routerlogin.net"), not an actual Netgear
("netgear.com") site.  As usual, an accurate description of what you did
would be more helpful than your interpretation of what it all means.
> [...] security questions, [...] answers are incorrect. [...]
   Reset the router, and reconfigure it.  Visit
http://netgear.com/support , put in your model number, and look for
Documentation.  Get the User Manual, and look for something like
"Factory Settings".  Then the section(s) on router configuration.
Message 2 of 3
Re: AC1900
There is support material, including a manual, for the R7000 somewhere at the end of this link:
>>>> R7000 | Product | Support | NETGEAR <<<<
The firmware is there too, with release notes that explain how to update the firmware:
R7000 Firmware Version 1.0.9.28 | Answer | NETGEAR Support
There is also a Hotfix that might become a new firmware release some time in the future,
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 353 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
