agarabaghi's avatar
agarabaghi
Follower
May 20, 2021
AC2200 WiFi Mesh Extender (EX7500) with Asus XT8
Was looking for a tri band solution to extend my existing mesh network (Asus XT8). Will this work and use the 2nd 5ghz band for backhaul or does it require Netgear products for that?
1 Reply
  • plemans's avatar
    It might work with the system but it isn't going to integrate with it.
    In my experience, if you have a current mesh system, its best to add its own compatible satellites to it.
    It can work without but tends to have a bit lesser performance/stability/integration.
