Reply
AC2400 Not Working - Only WiFi Light On
bcklsh
Tutor
So my son started mashing on the router buttons and now my router doesn't work.
The only LED light thats working is the WiFi On/Off.
All other lights are off.
I tried hard wiring directly to the router, but I cannot connect.  Any suggestions would be highly appreciated.
Model: AC2400|Nighthawk AC2400 Smart WiFi Router
Message 1 of 10
bcklsh
Tutor
Re: AC2400 Not Working - Only WiFi Light On
Additional info:
When i toggle the power switch or do a power cycle, only the WiFi button lights up.
Message 2 of 10
Guru
have you tried doing a reset on the router?
Hold the reset button on the back of the route for around 7-10 seconds. Hold it until the light change their blinking. Then release. it'll make you start up the router from the beginning.
Current Setup: CM2000-> RBK750-> GS716v2-> RAXE500-> Pi-hole->
Message 3 of 10
bcklsh
Tutor
tried doing a reset, but nothing happened. held for 10 seconds - 1 min. The only light that is on is the WiFi light. Power light is still off.
Message 4 of 10
Guru
You don't have specific model number but you can try using a tftp procedure to reinstall firmware. here's the instructions. Get the firmware for your specific model from the netgear.com/support/ site
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
Message 5 of 10
bcklsh
Tutor
Added router model
See below. The router is not getting power, so the PowerLED signals aren't matching. Additionally, when I try to turn the router back on while holding the reset button, only the WiFi light turns on.
Message 6 of 10
Guru
with his mashing did he:
1. Stick one of the buttons in so its always engaged?
2. Break one of the buttons off internally so its not sending a signal anymore?
Message 7 of 10
bcklsh
Tutor
Per my wife he pressed it a bunch of times.
Upon further inspection:
The buttons aren't stuck.
The buttons aren't broken - still make the clicking sound and don't feel stuck/lodged, if that makes sense.
Message 8 of 10
Guru
Did he somehow swap power supplies around?
Message 9 of 10
bcklsh
Tutor
lol nope still the same standard power supply that came with it. thinking it might be the hardware?
Message 10 of 10
Top Contributors
Discussion stats
  • 9 replies
  • 1475 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 6E
