Reply
AC3000 router as access point
badaddidude
Follower
Windows 10, r7900 tri-band router, made the mistake of clicking on the box labeled "access point" and now I cannot access the router at all.
I tried resetting it to no avail. How do I gain access to uncheck that box?
Model: R7900|Nighthawk X6 AC3000 Tri-Band WiFi Router
Message 1 of 3
antinode
Guru
Re: AC3000 router as access point
> [...] made the mistake of clicking on the box labeled "access point"
   Why?
> I tried resetting it [...]
   How, exactly?  Visit http://netgear.com/support , put in your model
number, and look for Documentation.  Get the User Manual.  Look for
"Factory Settings".
   What, exactly, happens when you try that?  Do the LED indicators
indicate anything interesting?
   You might also try doing the reset with nothing connected to the
router (except its power adapter).
> [...] to no avail. How do I gain access to uncheck that box?
   An actual settings reset should do the job.  Simply restarting the
router wouldn't.
Message 2 of 3
There is a manual for the R7900 somewhere at the end of this link:
>>>> R7900 | Product | Support | NETGEAR <<<<
Factory reset the thing, see Factory Settings, and reconfigure it from scratch.
Just another user with a set of boilerplate macros.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 868 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
