Orbi WiFi 7 RBE973
Reply
AC3200, R8000 does not support "dev tun"
ssriram1978
I am trying to use openVPN client in my iOS device to connect to my AC3200 router.
AC3200 does not support "dev tun" option in the ovpn setting.
I am unable to login to my VPN from iOS device.
However, I had AC1900 (R7000) which supported "dev tun" option in the ovpn setting.
I sold off my AC1900 and upgraded to AC3200 but it looks like I need to fall back to AC1900 because AC3200 does not "dev tun" option.
When are you planning to support "dev tun" option in AC3200?
Thanks,
Sriram
Model: R7900|Nighthawk X6 AC3000 Tri-Band WiFi Router
Message 1 of 8
Accepted Solutions
ElaineM
NETGEAR Employee Retired
Re: AC3200, R8000 does not support "dev tun"
@ssriram1978 Can you you confirm if the latest firmware fixes it?
R8000 Firmware Version 1.0.3.46
Message 6 of 8
All Replies
Guru
I'd contact either phone support about this or send a message to Elaine, one of the forum moderators about this. Good Luck.
Message 2 of 8
ElaineM
Let me make a follow-up on this.
Message 3 of 8
Guru
Thank you Elaine.
Message 4 of 8
ssriram1978
Thank You.
Here is the client debug log and it clearly points out the failure reason.
2017-04-26 10:52:46 SSL Handshake: TLSv1.0/TLS-DHE-RSA-WITH-3DES-EDE-CBC-SHA
2017-04-26 10:52:46 Session is ACTIVE
2017-04-26 10:52:46 EVENT: GET_CONFIG
2017-04-26 10:52:46 Sending PUSH_REQUEST to server...
2017-04-26 10:52:46 NET Internet:ReachableViaWWAN/WR t------
2017-04-26 10:52:46 OPTIONS:
0 [route] [192.168.0.1] [255.255.255.0]
1 [route-delay] [5]
2 [redirect-gateway] [def1]
3 [route-gateway] [dhcp]
4 [ping] [10]
5 [ping-restart] [120]
2017-04-26 10:52:46 PROTOCOL OPTIONS:
  cipher: AES-128-CBC
  digest: SHA1
  compress: LZO
  peer ID: -1
2017-04-26 10:52:46 EVENT: ASSIGN_IP
2017-04-26 10:52:46 TUN Error: tun_prop_error: one of ifconfig or ifconfig-ipv6 must be specified
2017-04-26 10:52:46 EVENT: TUN_SETUP_FAILED tun_prop_error: one of ifconfig or ifconfig-ipv6 must be specified [ERR]
2017-04-26 10:52:46 EVENT: DISCONNECTED
2017-04-26 10:52:46 Client exception in transport_recv: tun_exception: not connected
2017-04-26 10:52:46 Raw stats on disconnect:
  BYTES_IN : 3498
  BYTES_OUT : 2619
  PACKETS_IN : 35
  PACKETS_OUT : 35
  TUN_SETUP_FAILED : 1
2017-04-26 10:52:46 Performance stats on disconnect:
  CPU usage (microseconds): 79480
  Network bytes per CPU second: 76962
  Tunnel bytes per CPU second: 0
2017-04-26 10:52:46 EVENT: DISCONNECT_PENDING
2017-04-26 10:52:46 ----- OpenVPN Stop -----
Message 5 of 8
ElaineM
Message 6 of 8
ssriram1978
Thank you. The latest firmware has the ios ovpn details and it works fine.
Message 7 of 8
ElaineM
Thank you for the confirmation.
Have a great day!
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 7756 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
