- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
AC3200 X6 R8000 NOT WORKING all lights stay on but internet light
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: AC3200 X6 R8000 NOT WORKING all lights stay on but internet light
@USMC1775UCT wrote:
My router just stopped working nothing I can do to get any device to see it. I have unplugged it for hours and plugged it back in the lights all come on right away no flashing and they all stay on except the internet light.
From what I can make out from your photo, the power LED on your router is orange. That is wrong.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Check the section in the manual Troubleshoot With the LEDs.
You may have done this already. I can't tell from your message.
If I am right, then you may have corrupt firmware.
There is more severe, recovery reset, that you could try:
- Press reset for 30 seconds
- Keep pressing reset while removing power
- Keep pressing reset for another 30 seconds while apply power
If it works, you may be able to use the usual method to flash the firmware again.
Download the latest firmware for your device – or an older version if that is what you want – and read the Release Notes for how to install it.
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
If that fails, you are into TFTP country.
How to upload firmware to a NETGEAR router using Windows TFTP | Answer | NETGEAR Support
This also explains how to tell Windows to use TFTP on your PC.
This isn't the easiest operation, so if you are forced to use it, you could try a web search to find videos that guide you through the process.
The good news is that TFTP has rescued many a dead device.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
It is hard to tell from your description if you have followed the instructions in the TFTP link.
This is not an easy thing to do, so it may help to find a video that you can follow to take you through the process step by step:
tftp netgear video - Google Search
This is one of several:
The process is the same regardless of the brand of router.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Can you confirm that the power LED on the router of a steady amber colour and is not blinking?
That was a guess on my part. You did not tell us if this really is the case.
