Orbi WiFi 7 RBE973
Reply
AC3200
bigbuzzdj
Follower
AC3200
I own one of there wifi units and want to know if I can use this unit asa a stand alone hot spot in my RV??
Also does it have a place to place a sim card ito unit?
If yes what is the best way to use it?
Or will I need to connect to a laptop to make it work
Thanks for your helpl
Newbe with portable hot spots
Model: R8000|Nighthawk X6 AC3200 Smart WIFI Router
Message 1 of 2
Guru
Re: AC3200
If you're referring to the R8000, it doesn't have LTE/cellular connectivity.
You could connect it to some hotspots but by itself, it isn't one.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 250 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
