Orbi WiFi 7 RBE973
Reply
AP Mode and wired connection to TV
Cannedmeat
My router an old Apple AirPort Extreme and modem are located in my office and, I get a weak wifi signal in my living room. I'm considering buying the AC1900 and placing in the living room with both my smart TV and Apple TV and connecting the two routers with an Ethernet cable, running the ac1900 in AP mode and connecting cables from the AC1900 to my smart tv and Apple TV. Will this work and is it really necessary to connect cables between the router and tv-Apple TV. I'm under the impression the wired is better than wireless.
Thank you
Message 1 of 5
Accepted Solutions
William10a
Master
Re: AP Mode and wired connection to TV
Yes they will still work just fine with the router set up as a access point it just allows you to connect to the main router with wired and wifi devices if wifi is enable on the second router(access point) in a remote location.
Message 4 of 5
All Replies
William10a
Master
True wired connections can connect devices to to your at almost full speed of the internet you pay for and wireless has limits and walls can cut down on your range But a router as access point can bridge dead shots in a home with wifi can be a hit or miss like all wifi routers.
Message 2 of 5
Cannedmeat
Thank you for your reply. So now I understand that a wired connection is better than wireless, with the AC1900 connected to my primary router using ethernet, will the LAN ports on the AC1900 still function? It seems logical to me that they would, but I don't know for sure.
Thanks
Message 3 of 5
William10a
Master
Message 4 of 5
The easiest way to hard-wire a TV to a network is with a pair of powerline plugs.
Product FAQ: Powerline Adapters | Answer | NETGEAR Support
Powerline Networking | Powerline Ethernet | NETGEAR
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 5846 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
