- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
AX1800 RAX10 no remote management with this router?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I just purchased Netgear AX 1800 RAX 10 router and am unable to find remote management. I would like to make sure it is disabled. I have looked through the entire router web GUI four times and it is nowhere to be found although the users manual shows that it should be in the Advanced Setup section. Does this router not come with this feature?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: AX1800 RAX10 no remote management with this router?
> I just purchased Netgear AX 1800 RAX 10 router [...]
Firmware version?
> [...] I have looked through the entire router web GUI four times and
> be in the Advanced Setup section. [...]
Are you looking at:
ADVANCED > Setup > ???
or:
ADVANCED > Advanced Setup > Remote Management
Netgear's management interface structure has some potentially
confusing quirks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have looked through the entire router several times. including Advanced>Advanced Setup> The problem is that Remote management isn't there in the list of items to select from.
