- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
AX1800 and AC750 subnetting
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I have an environment where there are WiFi dead spots due to the location/achictecture. I am looking to purchase both an AX1800 and Ac750, but would like to cofirm a few assumptions regading their configurability.
According to the documentation, both of these devices are preconfigured witha default IP 192.168.1.1. The ISP provided device (Hwawei) has the same default, and cannot be altered, as that functionality is locked out.
I would like to change the AX1800 and AC750 to be 192.168.2.1 and 192.168.3.1. Enabling network isolation for the subnets.
This would require (from what I can see), one of the ports to have an IP in the192.168.1.X range to communicate to the primarys ISP device, and the remaining to be in the 192.168.2X, or 192.168.3.X range.
Does the firmware and configuration options alow this??
If not, can these devices be set with static addresses of 192.168.1.2 and 192.168.1.3, and have their DHCP issue for 192.1168.1.50-99 and 192.168.1.100-150 ranges respectivly.
I have not purchased these devices at this point, as I need to know whether there will be problems with configuration and compatibility. Due to Covid, I cannot determine the exact model of these devices,
Any ideas or suggestions?
Thanks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: AX1800 and AC750 subnetting
AC1800 and AC750 are speeds. Not models.
What actual routers or devices are you looking at?
by the time you buy 2x routers, you might have looked at investing in a mesh system that would do those.
the SXK30 is a mesh systems and allows 4x ssids with different vlans.
That'd accomplish what you're trying to do and it'd function with seamless roaming and the ability to add more sateliltes for additional coverage if needed.
1.4gig download/50mbps upload
We’re members of the public helping out on our own time.
