Orbi WiFi 7 RBE973
Reply
AX8 Nighthawk drops signal strength for no reason
redbird97
So my AX8 will just drop the strength to all of my devices for no reason. I noticed it more since i began streaming games from my PC to my iPad.
I checked the the signal strength in the app to my devices and it was one bar on everything (all wifi devices though show strong connection on the devices themselves). I found that doing a speedtest kicks the router in the butt and seems to get things back to a tolerable level for a little bit.
See the screenshot to see the before, and then immediately after running a speedtest.
Any ideas?
Model: RAX80|Nighthawk AX8 8-Stream WiFi Router
Message 1 of 6
Guru
Re: AX8 Nighthawk drops signal strength for no reason
Netgear has set up a community forum specifically for the NightHawk RAX WiFi 6 Router products:
https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/bd-p/en-home-routers-nighthawk-wif...
Thank you.
Message 2 of 6
redbird97
Firmware: 1.0.5.132_1.0.69
It's a Charter modem. That shouldn't have anything to do with the issue though as I'm not having an issue with the internet speed.
I live in the suburbs, there is no other wifi traffic.
Message 3 of 6
Guru
Message 4 of 6
That tells us nothing useful. Charter has supplied many different devices over the years. These days there is a good chance that they supply something that has everything to do with your Internet speed.
Suburbs = neighbours = wifi interference.
Message 5 of 6
redbird97
Maybe my message wasn’t clear enough. I have no issue with my internet speed. I have issue with signal strength dropping while streaming from my PC to my ipad. The modem and internet speed do not come into play whatsoever.
As far as wifi traffic. From any device in my house, if you look at available wifi, there is only my network. I do not receive any signal from a neighbors wifi.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 888 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
