Reply
Able to remotely login to router even if remote management is off
masterofnone
Follower
My R7000 has the same problem.  The "Turn Remote Management On" checkbox is unchecked yet when I go to it from the internet I get prompted for the username and password and then I'm able to logon.  I tried setting the "Onlyt from this computer field" to 10.10.10.10.  That didn't work either.  It didn't work before but I did a firmware upgrade and it still ignores the Turn Remote Management On checkbox.  Very dangerous!!!!
Model: R7000|AC1900 Smart WIFI Router
Message 1 of 2
JamesGL
Master
Re: Remote Management is turned ON when it is clearly OFF in adv settings!
Hi masterofnone,
What is the firmware version of your router?
JamesGL
Community Team
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 2015 views
  • 0 kudos
  • 2 in conversation
Announcements
