Reply
Ac1900 nighthawk wont connect to the internet
Chad420
Follower
So I just ordered a ac1900 nighthawk off amazon. I tried setting it up, but I couldn't connect to the internet, nor through the wifi. My modem is new from the cable company, and if I plug anything into the modem it works. But, when I put the router into the modem it trys to connect but always fails. I tried different ethernet cords and always the same fail. I can't even see it on my wifi listing on galaxy s6. I tried factory reseting it too (even though it's new. I'll call netgear and my Internet provider tomorrow.
Message 1 of 2
DexterJB
NETGEAR Moderator
Re: Ac1900 nighthawk wont connect to the internet
Hi @Chad420,
It is possible that the ISP is not recognizing the connection on your router. I recommend performing MAC spoofing on the router. You may refer to the link below for the steps:
http://kb.netgear.com/app/answers/detail/a_id/1086
Alternatively, you may contact us over the phone to get a step by step walk through on the process.
Dexter
Community Team
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 5115 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
