Reply
Access Control | netgear cannot allow a blocked device
diralex
hello,
My Netgear Router Firmware Version: V1.0.2.28
With access control enabled and rule: Block all new devices from connecting.
Recently I purchased a new notebook and netgear router blocked it's wifi.
I want to allow it's wifi connection, so I did:
1. I checked the radio button of the new notebook and pressed: ALLOW.
2. After the router had refreshed, I am still getting that the new notebook is blocked.
How can I allow a new device to become "not new" and put it's IP in the allowed list, and then block other new devices?
Best regards,
Loui.
Model: R7800|Nighthawk X4S AC2600 WiFi Router
Message 1 of 8
JamesGL
Master
Re: Access Control | netgear cannot allow a blocked device
Hi diralex,
Can you post the screenshot of your access control.
When you select the button of the new laptop, click edit. Change the option from block to allow then click apply.
Message 2 of 8
diralex
hi @JamesGL
This is screenshots:
1. With BLOCK mode - the notebook is blocked.
2. After V on the notebook and Allow and refresh - still blocked.
3. After edit mode - still blocked.
4. after edit mode and changing to Allow and Apply - still blocked (either in the main and the edit windows).
thanks
Message 3 of 8
JamesGL
Master
Hi diralex,
Reset the router to factory default and reconfigure the access control manually.
Message 4 of 8
JamesGL
Master
Hi diralex,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
Message 5 of 8
diralex
hi @JamesGL
After factory reset - now everything is ok Smiley Happy
But it was a lot of pain to manually re-assigh 11 Address Reservations.
Thank you very much.
Message 6 of 8
JamesGL
Master
Hi diralex,
Glad to know it is working now.
Message 7 of 8
diralex
Hi @JamesGL
Unfortunately, after I thought that the issue had solved, yesterday I attached a new device (Harmony Hub) to the router
and the problem occurred again.
Simply I cannot allow a new device because the router blocked it forever.
I think this is a firmware issue, because it's not reasonable that I should do a factory reset after every
new device that attached to the router.
Please your help.
Best regards.
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 3538 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 6E
