- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Access a camera outside my router's IP range
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi.
We installed a new Wifi Router Netgear Nighthawk R7000 in our office. This gave us a new IP Range 10.0.0.x for our internal setup, so I went through changing hosts file, printer IP addresses all over the place.
We cannot access our IP camera which used to be on IP 192.168.1.10 . I powercylced the camera but that camera still doesn't show up under connected devices in the netgear genie admin panel under connected devices. I think that IP is set on the camera itself.
I read that you cannot simply access a device outside the router's ip range (Netgear does not allow me to modify the 10.0.0 part, only the last digit). How can I access this camera on my network so I can change the IP and see it?
Our setup is Modem > Nighthawk > big switch > a bunch of PCs, printer and camera hardwired.
Thanks for your help, I run out of ideas!
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Why? Better wireless coverage, or some other reason?
Probably the wrong approach.
> Our setup is Modem > Nighthawk > big switch > [...]
What is "Modem"? If it's actually a modem+router (which seems
likely, if the R7000 chose "a new IP Range 10.0.0.x for our internal
setup") then you might have saved some effort and difficulty by
configuring the R7000 as a wireless access point. Cascading multiple
routers can cause multiple problems, such as this one.
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual. Look for "Use the Router as a
Wireless Access Point". That should put everything onto one big
(192.168.1.*) LAN, as before.
> range [...]
Where, exactly, did you read what, exactly?
If you insist on having two routers (hence two subnets), then there
are ways (not very far from "simply") to make that work. For example:
https://community.netgear.com/t5/x/x/m-p/1644757
https://community.netgear.com/t5/x/x/m-p/1558939
But configuring the R7000 as a WAP (and reverting all your IP address
changes) might be a better approach.
> [...] I think that IP is set on the camera itself.
If so, and if you want to use it on some other subnet, then you'd
need to reconfigure the camera. If it's simply connecting to the old
"Modem[+router?]", and getting its address from (the DHCP server on)
that router, then you may or may not need to fiddle with it.
> [...] I run out of ideas!
Not soon enough?
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
> range [...]
Not soon enough?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Access a camera outside my router's IP range
> We switched internet provider and we needed to buy our own router.
> too late, it's done.
> Modem is Spectrum Internet Cable modem, the installer put it in bridge mode
> I wanted to do that at first, but Spectrum does not grant access to log into their modem/router. So the only solution was to have our own router.
> range [...]
> On one of a dozen forums I researched before posting my question here.
> Thanks, we have only one router
> Thanks, I was able to factory reset the camera just now and it got a new IP address in my 10.0.0.x range. So everything works fine!
Not soon enough?
> Thanks for your help!
