Orbi WiFi 7 RBE973
Reply
Accessing MB8600 Configuration page through r7000
HelpfulDad
Can anyone give me the secret sauce that will enable me to reach a Motorola MB8600 login page of the modem attached on my WAN port on the router from a device on the r7000 LAN?
R7000 is configured for Class B at 192168.x.x with it's own address at 192.168.0.1.
Motorola says its at 192.168.100.1 on a sticker on the bottom of it.
Router is not configured to login to the ISP.
I had the same problem when it was configured for a Class C LAN at 192.168.0.1.
I am unable to ping 192.168.100.1 either.
There was a suggestion that I configure my LAN at 10.x.x.x and then the router will forward it thourgh the wan port, but this is a pain in the butt, so if there is a way I can get this to work without doing that, I'd rather.
If I plug directly into the modem port with a windows PC, it's fine.
Model: R7000|AC1900 Smart WIFI Router
Message 1 of 9
antinode
Guru
Re: Accessing MB8600 Configuration page through r7000
> 192.168.0.1.
   A router like an R7000 has two interfaces.  You mean its (not "it's")
LAN interface?  Why "Class B" (other than to cause problems like this)?
   "192.168.0.0/16" tells the R7000 that "192.168.*.*", including
"192.168.100.1" is on its LAN.  Assuming that your MB8600 is actually
connected to the WAN/Internet interface of the R7000, that would seem
to be misleading.
   Same problem, I'd say.
> 192.168.0.1.
   Perhaps, but that (default) configuration would have had a chance of
working.  I'd return the R7000 to its default configuration (a settings
reset might be the safest way to be sure), and start again.  Whatever
problem you might have had, changing the R7000 LAN subnet mask is not
the cure.
Message 2 of 9
HelpfulDad
So basically, you responded to correct my punctuation?LOL
Message 3 of 9
antinode
Guru
   In case you missed it, "192.168.0.0/16" can't work.  I know nothing
about what you did before you got creative.  Look for "I'd".
   None of what you posted about the original ("192.168.0.0/24")
configuration is a useful problem description.  It does not say what you
did.  It does not say what happened when you did it.  As usual, showing
actual actions (commands) with their actual results (error messages, LED
indicators, ...) can be more helpful than vague descriptions or
interpretations.
   Visit http://netgear.com/support , put in your model number, and look
for Documentation.  Get the User Manual (at least).  Read.  Look for the
LED descriptions and "Troubleshoot".
Message 4 of 9
HelpfulDad
It comes out of the box as /24 and as I said, didn’t work as it was either.
Such a pejorative tone. If you have nothing to add, then don’t respond because I’m not looking punctuation assistance.
I don’t understand why people act like this. Your tone is so off putting that I, and others, just avoid coming to places like this for help. I’m looking for someone who has seen this before and can help. Clearly you haven’t nor do you know how to do this so I’ll just wait for someone who does or, more likely, Ill continue in the other channel until someone provides some input or I’ll figure it out myself.
Model: A7000|Nighthawk AC1900 WiFi USB Adapter - USB 3.0
Message 5 of 9
antinode
Guru
> It comes out of the box as /24 and as I said, didn't work as it was
> either.
   You said that.  But, regarding "didn't work", see "useful problem
description [...]", above.
      "My car wasn't working.  I filled the fuel tank with soapy water."
      "Drain the water from fuel tank, dry it, and add proper fuel."
      "But it didn't work that way."
      "I know nothing about your original problem."
      "I'm looking for someone who has seen this before and can help."
   "seen" _what_, exactly?
Message 6 of 9
HelpfulDad
then don't answer.  It's not like you've been helpful anyway.
Message 7 of 9
antinode
Guru
> then don't answer. [...]
   Same to you.  I was still waiting for a useful description of the
problem _before_ you decided to fix everything by changing a subnet mask
so that nothing could be expected to work.
> [...] It's not like you've been helpful anyway.
   If you expect "helpful" without answering basic questions, then you
might benefit from the results of a Web search for:
      "life is like a sewer"
Message 8 of 9
Why do you want to do this?
There isn't much that you can do to a modem's settings. You can't even change the firmware on a cable modem, because that is the ISP's prerogative. Most of the useful controls are done on the router.
When a modem sits in front of a router the normal procedure – as described in the manuals – seems to be to disconnect from the router and plug directly into the modem. Then you can use its own IP address.
That's about it.
Messing around with IP addresses as you are is probably doomed to fail. You are trying to break how these things work. In the process, you may be making life more difficult for yourself with things that you can control.
Then again, if you explained want to tunnel into the modem, someone may have a solution.
Message 9 of 9
Top Contributors
Discussion stats
  • 8 replies
  • 2398 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
