Reply
Additional WiFi Router with Nighthawk R7000P
Sledgehammer
Initiate
I have a new R7000P wifi router in my main house and my tenant in my guest house is using his own Syslink router. His router is hardwired with a cat5 cable running from my R7000P router into the guest house. For whatever reason his router does not work ever since I made the switch.
What am I missing?
Model: R7000P|Nighthawk AC2300 Smart WiFi Dual Band Gigabit Router
Message 1 of 4
Guru
Re: Additional WiFi Router with Nighthawk R7000P
If both devices are in route rmode, you're in a double nat. It can cause many issues.
https://kb.netgear.com/30186/What-is-Double-NAT
Try having the guest house router placed in access point mode. (if your R7000P is the entry point to the home for internet)
How far is the ethernet run to the guest house?
I
If you plug a computer into the run thats going to the guest house, does it work?
Current Setup: CM2000-> RBK750-> GS716v2-> RAXE500-> Pi-hole->
Message 2 of 4
Sledgehammer
Initiate
You were right. I was able to set them up as cascading modems and it now works great! Thank you!
Message 3 of 4
Guru
happy to hear you got it working the way you wanted it to!
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 297 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 6E
