Reply
Admin password
Richb777
Follower
Admin password
I know my wifi password but I cant access my router settings Ive tried using the default password with no success do I have to  do a factory reset and if so will that change my wifi password any help would be welcome
Model: R8000|Nighthawk X6 AC3200 Smart WIFI Router
Message 1 of 2
antinode
Guru
Re: Admin password
> [...] Ive tried using the default password with no success [...]
   Which "the default password" did you try?  (And which user name?)
> [...] do I have to  do a factory reset [...]
   That's the usual course.
> [...] and if so will that change my wifi password
   Yes, and every other non-default setting.
   Visit http://netgear.com/support , put in your model number, and look
for Documentation.  Get the User Manual.  Look for "Factory Reset".
Message 2 of 2
Discussion stats
  • 1 reply
  • 230 views
  • 0 kudos
  • 2 in conversation
Announcements
