3li's avatar
3li
Follower
May 11, 2021
After enabling QoS the 2.5ghz network won't broadcast
I enabled QoS on my gateway for a game. I then realized that the 2.5ghz network no longer showed up. Only the 5ghz network was there. I disabled QoS and it didnt fix it. I reset the router to factory settings twice. I manually upgraded the firmware. I tried all the channels and modes but the 2.5ghz network will not show up. it looks fine in the routerlogin page but i cant find it or connect to it. I was working perfectly fine before and now it just wont show up.
No RepliesBe the first to reply
