Reply
After firmware update, my login password does not work.
Nightfly72
Follower
After firmware update, my login password does not work. When I attempt to reset per the instructions, and I enter the serial number, the site does not continue when I hit "Continue"
Model: C7000|Nighthawk - AC1900 WiFi Cable Modem Router
Message 1 of 2
Re: After firmware update, my login password does not work.
Greetings,
This is a known issue and behavior.  The recovery does not continue after S/N entry because it was never configured.
If you absolutely cannot remember your PW, the only way to resolve this is to factory reset and perform a set up from scratch.
~Comcast 1 Gbps/50 Mbps SB8200 > R8000P
~R8000P FW:1.4.1.68 ~R7000 FW:1.0.9.42
~R6400 FW:1.0.1.52 ~Orbi-AC3000 FW:2.5.1.8
~EX3700 FW:1.0.0.84
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 268 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
