- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
After installing new firmware R7000-V1.0.9.34_10.2.36 my Wifi is broken constantly, i need to reboot
- Mark as New
- Bookmark
- Subscribe
- Permalink
After installing new firmware R7000-V1.0.9.34_10.2.36 my Wifi is broken constantly, i need to reboot, what to do to solve this issue ?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try a factory reset. if that doesn't fix it, you may need to go back to a previous version. Also, reconfigure your mobile devices by forgetting the wifi SSID and setting it up again
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: After installing new firmware R7000-V1.0.9.34_10.2.36 my Wifi is broken constantly, i need to re
This worked fine as solution, but now i have slow connection on the 2.4 ghz band , ths 5 Ghz band works ok, how can i tune up the 2.4 band
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try to adjust the wireless channel of the 2.4ghz
https://kb.netgear.com/23783/Improving-2-4Ghz-Wireless-Performance-by-Changing-Channel
https://kb.netgear.com/25182/Resolving-poor-5GHz-wireless-range-signal-from-my-NETGEAR-router
DarrenM
