Reply
Highlighted
After update
After updating the router I can not access the router and I can not reset the factory settings.
Model: R7800|Nighthawk X4S AC2600 WiFi Router
Message 1 of 8
Highlighted
Apprentice
Re: After update
OK.  You will need more divulge more information for us to understand the problem(s).  How are you trying to access the router...  telepathically or via more traditonal methods such as routerlogin.net or 192.168.0.1/192.168.1.1?  In the app or browser?  What happens after you reset the router???  Is the SSID boradcasting etc...
Message 2 of 8
Highlighted
Master
Re: After update
What are the light of the router doing?
Message 3 of 8
Highlighted
Re: After update
I update router from the app to the last update , but after that I cannot find the Wi-Fi Signal or when I connected it to ethernet cannot access router setting.
Message 4 of 8
Highlighted
Re: After update
blink orange
Message 5 of 8
Highlighted
Master
Re: After update
Sounds like the firmware update went wrong and now the router can not boot fully, do you know to do a ipcomfig in the command prompt window of windows if you run windows on your computer you will need to connected via a lan cable to the router?
If you can find what ip address router is putting out you may tffp into the router and reflash it with new firmware, this time do it with the app you used before.
Message 6 of 8
Highlighted
Re: After update
Message 7 of 8
Highlighted
Re: After update
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 377 views
  • 0 kudos
  • 3 in conversation
Announcements
