- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- « Previous
- 1
- 2
- Next »
After updating R7800 to firmware 1.0.2.36 Time Machine can't see network drive
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: After updating R7800 to firmware 1.0.2.36 Time Machine can't see network drive
Are you able to see the drives in the router's configuration page? Can you show us a picture of the config (Advanced ->ReadyShare->Basic Settings? Are you password protecting them?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have a 2017 iMac with a 1TB SSD and I use Thunderbolt 3, its way faster so why would you want to use the router? The point should be you need to back up and worry about the router after you have some backups? Even USB from your mac would be better that relying on the router.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'll send you this evening.
Thank you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I can't understand what is your problem 🙂
That's the point: I want to backup my Mac wireless to an SSD attached to my Netgear R7800. Am I crazy? Maybe yes, I just want to do it.
I know that via thunderbolt/usb C is absolutely faster, i surely know. But I want to do this thing anyway and I need help from community in order to solve my problem, lot of other people can do backup like this.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I know, I know. USB is faster, better and lot of things, trust me, I know.
But i want do it anyway, everyone can make wireless backup with Time Machine and i want too.
- Mark as New
- Bookmark
- Subscribe
- Permalink
It's the old "only-data" drive from my old MBP, used just few months. Being a 500GB i think that can be used for my purpose, am I wrong?
- Mark as New
- Bookmark
- Subscribe
- Permalink
It was just an internal disk to put some data (movie, images etc..) replacing the superdrive. It was not used for backup. Why?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Excuse me, but the name of this thread is "After updating R7800 to firmware 1.0.2.36 Time Machine can't see network drive", so the author (and others) are using Time Machine with their R7800. I want to, what is the problem with this?
We are running out of the thread, my question was easy and inherent the main question of this thread. If you want to continue to suggest me to not do this, stop to reply me please. I'm looking for someone that can solve the problem of this thread also after the upgrade to 1.0.2.38, maybe I have just some bad configuration on my router.
- Mark as New
- Bookmark
- Subscribe
- Permalink
After doing some tests, the new firmware (1.0.2.38) fixed the smb (drive access via Finder) but it did not fix the afp (apple file protocol) ,which is required for time machine. I went back to the Voxel firmware.
The easiest way to see if the afp is working is to go to the Finder Menu then Go-> Connect to server and type this afp://YOUR_ROUTER_NAME [Your router name can be found in the router web page (Advanced->ReadyShare->Basic Settings].
So I was wrong when I said earlier that it was fixed, it was not fixed in 1.0.2.38 (at least for me)
Use a firmware prior to 1.0.2.36 or use Voxel's firmware for the X4S (Google it, it is easy to find)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Dont ever use old firmware with security vulnerabilities. Some are really serious and you should run Voxels latest or netgears, even Voxel agrees on that in a post on on snb. Don't give out bad information please it puts users at risk.
- Mark as New
- Bookmark
- Subscribe
- Permalink
While this is generally sound advice, some security vulnerabilities depend on how you run your hardware. For example, if you worry about the KRACK issue, this affects routers only if you put them into bridge mode:
Netgear updated that advisory earlier this week.
If KRACK really scares you, then stop using any wifi clients you own. That's where the danger lies.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm not worried about Krack that much tb, I don't run in AP mode and slowly my clients are being updated. Personally when Netgear say to update to avoid a command injection vulnarbility, well I think you should, it would be nice though if they didn't add more bugs to their rickety code with each update. Also metioning 'krack' that Netgear article says for R7800 firmware prior to 1.0.2.36 yet does not say its fixed in R7800 (I dont think it is) which is not helpful.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Are you running your time machine drive in HFS+ or APFS? It should be HFS+ still.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Killhippie wrote:
....it would be nice though if they didn't add more bugs to their rickety code with each update.
You can say that again. This seems to be the cause of too many recent problems.
Netgear rushes to plug a security issues that does not affect most users – and that takes quite some effort to exploit – but in the process manages to break important things.
The solution seems to be to stick with the old firmware that works and leave your router in router mode. Then get all your wifi clients fixed if the KRACK thing rally worries you.
- « Previous
- 1
- 2
- Next »
