Reply
Highlighted
Follower
Allow ESET Cloud Domains in Nighthawk R8000
Looking for some help from the Community.  I do some IT work for my Chiropractor, they have a Nighthawk R8000 router.  I recently had them purchase ESET EndPoint Protection for their Antivirus and such.  It appears that the router is preventing access for the Cloud Portal to manage the devices.
How would I update the router settings for these ports/URLs.
Thanks in advance..
These prerequisites must be met for ECA to work correctly:
These domains and ports must be allowed in your network firewall for ECA to work correctly:
DomainPort Type / Port NumberDescription
eba.eset.com
TCP/443
ESET Business Account
identity.eset.com
TCP/443
ESET Identity  Server
eca.eset.com
TCP/443
ESET Cloud Administrator
eu01.eca.eset.com
TCP/443
ESET Cloud Administrator Web Console Location: Europe
us01.eca.eset.com
TCP/443
ESET Cloud Administrator Web Console Location: USA
*.a.ecaserver.eset.com
TCP/443
Connection between the Agent and ECA
edf.eset.com
TCP/443
ECA Live Installer
repository.eset.com
TCP/80
ECA Live Installer. Repository  required for deployment.
epns.eset.com
TCP/8883
Connection for EPNS service (Wake-up Call, Single sign-on, License sync between ECA and EBA)
ECA Remote Deployment Tool:
ProtocolPortUsageDescriptions
TCP
139
Target port from the point of view of ECA
Using the share ADMIN$
TCP
445
Direct access to shared resources using TCP/IP during remote installation (an alternative to TCP 139)
UDP
137
Name resolution during remote install
UDP
138
Browse during remote install
Model: R8000|Nighthawk X6 AC3200 Smart WIFI Router
Message 1 of 4
Highlighted
Guru
Re: Allow ESET Cloud Domains in Nighthawk R8000
Well, most firewalls are typically IP based anyway, only proxy-like stuff can block domain URLs. Here we face simple consumer router, which does per se allow any outgoing connections. So why bother?
Message 2 of 4
Highlighted
____________________________________________________________________________
Great answer!!
Spot on, - problem solved...  Smiley LOL   Smiley Tongue
English is not my  native tongue  so i may have  misunderstood  something here but i do get a feeling that something aint working for him and  thats why he   bothered  to wrote here in the first place
Message 3 of 4
Highlighted
@PCTECHAZ :
what firmware are you on?
smileywink:
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 296 views
  • 0 kudos
  • 3 in conversation
Announcements
