× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Already has wifi name and password
sun9wilson
Follower
Hooked it up and it already has Wi-Fi name and a password. I can't get in and don't know what to do now. I just bought it I have never used it.
It's a netgear ax1800 Wi-Fi router..
Model# rax20
Model: RAX200|Nighthawk Tri-band AX12 12-Stream Wi-Fi 6 Router
Message 1 of 2
microchip8
Master
Re: Already has wifi name and password
The factory WiFi password should be printed on the router's label on the underside of the router. If not, connect it with a cable to one LAN port, use a browser and go to http://routerlogin.net or http://192.168.1.1 and login with "admin" and "password". Then you can change whatever you like
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 499 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
