Orbi WiFi 7 RBE973
Reply
Amber Light (solid) & WiFi Strength is Sporadic
Habs77
Follower
Needed to replace my older router so picked-up the Netgear AC1200 R6120.  I have internet access however the internet light on the router is a solid amber red.  What does this mean?
Also, the wifi strength seems to randomly get weak for no reason, regardless if on 2.4 or 5ghz.  I live in a condo so size of the home should not be an issue.  Tried changing the channels on both the 2.4 and 5 & that did nothing.
Model: R6120|AC1200 Dual Band WiFi Router
Message 1 of 1
Top Contributors
Discussion stats
  • 0 replies
  • 183 views
  • 0 kudos
  • 1 in conversation
Announcements
Orbi WiFi 7
