- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Amber led
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Hi,
Please help me with the following topic.
I connect a DVR on one of my router ports and is amber colour.
What kind of problem could be.I have other components connected on other ports and are normal color, white.I changed the port and the patch but is the same problem.Thank u
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
As long as it works, no problem. Check the spec's on the DVR for its Ethernet speed and if it is 1GB, change the cable connecting it. However, 100Mbps is usually more than enough for video.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: Amber led
Amber on a port LED if Amber means there is a 100Mbps connection. Either dictated by the device or cable used.
Same information that is in the R7000 manual.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: Amber led
@Mese wrote:
Thk , so is nothing to be concern about.
Thats correct. The routers ethernet ports support 10/100/1000 Mbps. If you connect a gigabit device that negotiates connection at full speed, the port LED will be white. If you connect a device whose speed is lower (say 10/100) the port LED will display amber as @IrvSp mentioned.
@IrvSp, sorry for posting over your answer.
~R8000P FW:1.4.1.68 ~R7000 FW:1.0.9.42
~R6400 FW:1.0.1.52 ~Orbi-AC3000 FW:2.5.1.8
~EX3700 FW:1.0.0.84
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
