- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Amber leds
- Mark as New
- Bookmark
- Subscribe
- Permalink
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
The Arlo base station Ethernet is 10/100 so it will show amber. Just a FYI, the USB is USB2. Arlo says no more speed needed. Have not had any issues with mine. Does feel like they are being cheap, but if it works then no worrries. Not like you are looking for some high speed performance, it is just pushing video clips to WEB and USB drive if you are using a drive.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Amber leds
if connected and working and you get amber, it means the device(s) operate at 100 or 10 Mbps instead of 1 Gbps. This is nomal indicator of the router so nothing to worry
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Amber leds
> [...] Nighthawk ac1900, [...]
"AC1900" is a speed, not a model number. Ever helpful, Netgear
product packaging emphasizes speeds like "ACxxxx", but that's not the
model identifier. Look at the product label.
> Model: D7000|Nighthawk AC1900 VDSL/ADSL Modem Router
Is that accurate? (Not "D7000v2"?)
Visit http://netgear.com/support , put in your (actual) model number,
and look for Documentation. Get the User Manual. Look for the
description of the LED indicators, and what the colors mean.
> [...] an arlo camera base station [...] an O2 signal booster. [...]
Also not model numbers.
> [...] This is nomal indicator of the router so nothing to worry
Unless it's caused by a bad cable, rather than by a slow device.
Gigabit speed uses all eight conductors; 10/100MHz needs only four.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
