GlowJoe's avatar
GlowJoe
Amber light # 3
I have an amber light on #3.
Have no clue as to what this is. Tried rebooting, but still remains solid amber.
1 Reply
  • schumaku's avatar
    schumaku
    On a Nighthawk router with Gigabit Ethernet ports it does indicate a 100 Mb/s or 10 Mb/s link - either because there is a non-Gigabit capable device plugged, or in case of a Gigabit capable device the cabling is not complete or correctly wired.
    Head to https://netgear.com/support , type your Nighthawk model, and consult the fine documentation on the LEDs FMI.
