Orbi WiFi 7 RBE973
Reply
Amber light
Ajjr32
Follower
Amber light
Solid white light becomes solid amber on my router when desktop computer enters sleep mode. Replaced Ethernet cable, no change.
Model: R7000P|Nighthawk AC2300 Smart WiFi Dual Band Gigabit Router
Message 1 of 2
antinode
Guru
Re: Amber light
> [...] Solid white light becomes solid amber on my router [...]
   How many lights are there on your "my router"?  _Which_ "Solid white
light becomes solid amber on [your] router?
   Visit http://netgear.com/support , put in your model number, and look
for Documentation.  Get the User Manual (at least).  Read.  Look for the
LED descriptions.  Now that we know what "amber" means, ...
> [...] when desktop computer enters sleep mode. [...]
   On some computers/devices (such as your (unspecified) "desktop
computer", apparently), an Ethernet interface will run at 100MHz when
the device is in a standby or (not-truly) "off" mode.  When such a
device is awakened or powered on, it may negotiate a faster link rate.
   If the computer's sleeping, then how important to you is the speed of
its Ethernet interface?
> [...] Replaced Ethernet cable, [...]
   If the cable was good when the computer was powered on, then I'd bet
that it stayed good when the computer was shut down.
   Don't worry; be happy?
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 244 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
