Reply
Android readycloud not syncing media automatic
Gmember
Hey guys,
Don't know if this is just the concept of the app or the limitatition or whatever but.....
I have readycloud installed in my android phone and turned on "media backup"......and it works but.... i need to open the readycloud app to sync the media..
It's does not sync on the fly when i take a picture as the dropbox app does..
Im i doing something wrong here? i mean in the readycloud you need to check "media backup" to sync but what use is it if it isn't doing it automatic??
Message 1 of 5
JennC
NETGEAR Employee Retired
Re: Android readycloud not syncing media automatic
Hello Gmember,
Which ReadyNAS product to you use with the ReadyCloud app?
JennC
NETGEAR Community Team
Message 2 of 5
Gmember
The Nighthawk AC1900 with latest firmware....
But it's the app that doesn't sync without opening it first on my phone.
Message 3 of 5
JennC
Hello Gmember,
I will move your post to the right board as this is ReadyNAS board.
JennC
Message 4 of 5
JamesGL
Master
Hi Gmember,
It is how it works. You need the ReadyCloud App to run for back up to work.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 2285 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
