Reply
Arlo enable button R7000 router
wash
Recently my Arlo base station have been found to be defective and I was issued an RMA to return the unit.  In the meantime I have been trying to sync my Arlo wireless cameras to my Netgear R7000 router with no success.
First of all I can't find the Arlo enable/disable button in Netgear Genie or http://www.routerlogin.net.   One thing I did notice however is when I check the device connect list in Netgear Genie, I do see the cameras connected under the R7000 router, but the cameras do not show up on any of the Arlo apps.  Can someone help?
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 1 of 3
Accepted Solutions
Retired_Member
Not applicable
Re: Arlo enable button R7000 router
Current r7000 FW does'nt support Arlo anymore.
Message 2 of 3
All Replies
Retired_Member
Not applicable
Message 2 of 3
wash
Thank You
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 2547 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
