- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Arris SB8200 receiving 800mgb but Nighthawk R7000 router only recording 240 mgb download speed
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi
my modem is recieving 800 mgb of download speed but nighthawk router only registering 240 mgb......how can I fix this issue?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Arris SB8200 receiving 800mgb but Nighthawk R7000 router only recording 240 mgb download speed
1. what firmware is on the r7000?
2. how are you testing speeds on the r7000? through the nighthawk app? through a wireless app? hardwired into the router?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I check the speed using the wireless app
Does that help?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Which wireless app?
the nighthawk (which hosts the test on the router) or the speedtest app (hosts the test on wireless device)?
Its kind of key as wireless isn't going to hit much more than 300+mbps on the R7000.
Wired you can potentially get close to the 800mbps but even that is only with all the extras disabled (parental controls, access controls, qos, traffic monitoring, etc)
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
What speed do you get if you hardwire a pc/laptop into the router? Not wireless. not using an app.
If you're using speedtest, try multiple servers
- Mark as New
- Bookmark
- Subscribe
- Permalink
As I understand it, and by my owns tests and the app's description, the speedtest in the Nighthawk app measures the wired speed between the router and the modem. It is not a wifi test.
You can test this yourself by testing inside the app and then again with a separate speedtest app.
In my case, the Nighthawk speedtest is in line with my Internet speed. Wifi tests are always slower.
