Reply
Attached Device Icons
dubbls
Ever since the last firmware update,(Firmware Version
V1.0.9.34_10.2.36) my device icons will not stay changed.
For instance, I enter the windows PC icon to my computer and update, and it goes back to a random icon on the attached deivces screen. This happens on all of the devices I try to edit with an icon from the dropdown list.
Can you help?
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 1 of 3
Christian_R
NETGEAR Moderator
Re: Attached Device Icons
Hello @dubbls
Please take a look at this community post that could possibly solve your issue:
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/Connected-devices-icons-no-longer-an-option/...
You may also use this link to disable/enable your QoS:
https://kb.netgear.com/24307/How-do-I-disable-Wi-Fi-Multimedia-Quality-of-Service-on-my-Nighthawk-ro...
Please let me know if this fixes your issue.
Christian
Message 2 of 3
vulture2600
Hello,
Ever since software update to V1.0.1.48_10.0.46 on my AC1750, I also have the same problem with icon and name changes not sticking.
I have disabled QoS and re-enabled it and it did not work. There are no firmware updates or QoS updates. I have tried both. Anyone else still having this issue?
Thanks!
Model: R6700|Nighthawk AC1750 Smart WiFi Router
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1320 views
  • 0 kudos
  • 3 in conversation
Announcements
