Reply
Attached Device Not Showing
NZID
Follower
I am connected to my R7000p router and I am looking at the list of attached devices, but the laptop I am connecting from (via wifi) does not show. However, when I go to ''add'' device through the "Lan Setup" option (to reserve an IP address), the ip address is listed, indicating it is currently connected. Even if I reserve an IP address for the device, it still does not show up on the list of connected devices.
Is this a known issue, and is there a fix?
Thanks
Model: R7000P|Nighthawk AC2300 Smart WiFi Dual Band Gigabit Router
Message 1 of 2
KSUrooter
Re: Attached Device Not Showing
I have essentially the same problem, but slightly different.
I try to add a device & it does show up in the list of attached devices, but I can't add the correct "device name",ie interior camera or the model name to that listed item. There are some devices in another area of the administration tab & I can change those names, but things won't cross back to the other area to match what corresponds to the correct name.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 517 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
