Reply
Attached usb not read correctly through ReadyCLOUD
sgates
I have attached an external, powered Seagate 3Tb USB drive to my R6700 Nighthawk Router. I have 2 partitions, NTFS 2Tb and HFS+ 2.5Tb for my MAC. ReadyShare reads the drive info correctly. However, when using ReadyCLOUD the shows 2 drives both with 4.5TB available each for a total of 9 TB. ReadyCLOUD will not show the contents and simply shows my drives as USB0 and USB1 and will not show any files in either.
Problems:
Incorrect size reporting
Incorrect Name reporting
Not showing files
Is this normal?
Message 1 of 4
JamesGL
Master
Re: Attached usb not read correctly through ReadyCLOUD
Message 2 of 4
sgates
Hi JamesGL - This did not resolve my issue. I am able to see my external drive. I am also able to see that there are two partitions (shows up as USB0 and USB1) each with 4.5 Tb for a total of 9Tb. The drive is a 5Tb and partitioned 2.5Tb HFS+ (for MAC Time Machine) and a NTSF 2.0Tb partition.
I went through the steps and unregistered the device, delete the account and open a new account. It appeared exactly the same.
Thank you for responding!!
Message 3 of 4
JamesGL
Master
Can you perform a factory reset on the device.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 2002 views
  • 0 kudos
  • 2 in conversation
Announcements
