- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Avast Securty 14.9 is giving a vulnerability warning
- Mark as New
- Bookmark
- Subscribe
- Permalink
Firmware on my R7000 is V1.0.9.88_10.2.88. When I try to upgrade, it says that I am current.
No real details from Avast on the vulnerabilty. Here is a screen capture.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Avast Securty 14.9 is giving a vulnerability warning
https://community.netgear.com/t5/x/x/m-p/2069376#M186506
> No real details from Avast [...]
Not much I can do with that.
I can't (yet) see your picture. In-line images must be approved
by a moderator before others can see them. The time required varies.
Attachments have no such limitation. Of course, attachments have their
own one-per-message limitation. In the mean time, copy+paste is your
friend.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@mynameisrobo wrote:Firmware on my R7000 is V1.0.9.88_10.2.88. When I try to upgrade, it says that I am current.
You're 5 firmware updates behind the most current one:
https://kb.netgear.com/000063684/R7000-Firmware-Version-1-0-11-123-Hot-Fix
Auto router update doesn't work on this router, well it has never worked on mine AC1900 model, so just disable it.
As for firmware updates, I recommend you do a manual check at least once a month because that's the only way you'll find out if you're on the most up to date firmware.
- Mark as New
- Bookmark
- Subscribe
- Permalink
The vague message you received is hardly an indication that Avast knows what it is talking about.
These things happen from time time to time:
Search - NETGEAR Communities – avast security
Security software is great at throwing up scary messages. They are often down to errors in its own software.
Try starting here:
Security Advisory | About Us | NETGEAR
