Orbi WiFi 7 RBE973
Reply
Avb network
Rogarc1
Avb network
Hi,
I need tips for avb network vía WiFi, is possible?
Regards
Model: R8000|Nighthawk X6 AC3200 Smart WIFI Router
Message 1 of 4
Re: Avb network
Not much to go on there.
What's AVB? Audio Video Bridging?
Are you trying to connect a particular device to your R8000 network?
Message 2 of 4
Rogarc1
Re: Avb network
Yes, I have Presonus mixer with AVB network (CS18ai and RM32AI)
Message 3 of 4
Re: Avb network
They will know more than anyone here about the configuration you need to connect the thing to the wifi. All routers will be in the same boat.
Find out from them what you need to do, and check the manuals for the R8000 about how to achieve this.
Or consult people here about the fine details.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 512 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
