Reply
BRAND NEW R7000 requires power cycle about once per week
snoobler
Purchased 10/15/17
Updated to V1.0.9.12_1.2.23
In order to get Internet connectivity, I had to set the route MAC Address to my Desktop address.  My ISP changed something, and this was required to get internet (on my previous router too).
Desktop attached via Gigabit
NAS attached via Gigabit
Muliple wireless devices attached (phones, tablets, laptop, smart TV). Typically less than 6 devices in operation at any given time besides phone/tablet auto-sync, etc.
DHCP used for all IP addresses.  The desktop and NAS use reserved addresses through DHCP.
All wired and wireless LAN/WAN operations are perfect.  Fast, never a wifi drop, etc.  Zero complaints.
Twice since purchase the router loses ALL functionality.
Router can't be pinged from desktop command prompt.
Router can't be accessed via web interface.
Desktop can't access NAS over LAN
Wireless devices show a connection to the router, but they can't access LAN or WAN.
Power cycling the router restores full function.
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 1 of 22
JamesGL
Master
Re: BRAND NEW R7000 requires power cycle about once per week
Hi snoobler,
Try to reset the router to factory default and reconfigure.
Message 2 of 22
JamesGL
Master
Hi snoobler,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
Message 3 of 22
snoobler
Since I posted, it hasn't done it again. Upon the next instance, I will do as advised; however, I don't expect much. The unit required a firmware update upon deployment.  Since very little customization had been done, I already did a factory default reset following the firmware update.  In other words, this behavior is after a reset to factory defaults.
Message 4 of 22
snoobler
It has done it again, but in a different way. The LAN and WAN are functional for hard lines, but wifi is completely down as is the web interface.  Devices can't connect to Wifi if not connected, and if they show as connected, they have no access to LAN or WAN.
The router reponds to pings to its local IP address from a hardlined computer.
The router does NOT respond to http requests for admin.
I will power cycle the router and execute a reset to factory defaults.
Message 5 of 22
snoobler
And again.  Exact same issue as my above post.  Hard line devices and LAN works, but wi-fi and hard line access of the web interface is completely inoperative.
Firmware V1.0.9.12_1.2.23
No updates available
Power cycle corrected it.
EDIT:  Router update function from web interface doesn't detect it, but support website says 1.0.9.14_1.2.25 is available. Downloaded and installed.
Message 6 of 22
snoobler
And again.
Wifi is down
Web interface is down from wired or wireless access.
Wired LAN devices are working
Still on V1.0.9.14_1.2.25
Updating to 1.0.9.18_1.2.27 through web interface
Message 7 of 22
Jsleek
Same issue with me. Exactly. I think the rotor is faulty at this point. Would not recommend it to friends.
Message 8 of 22
snoobler
And again.
Wifi is down
V1.0.9.18_1.2.27
Message 9 of 22
JamesGL
Master
Hi All,
Make sure to update the firmware to this firmware.
https://kb.netgear.com/000053870/R7000-Firmware-Version-1-0-9-26-Hot-Fix
Message 10 of 22
snoobler
The current installed version is:
V1.0.9.18_1.2.27
Are you saying I should downgrade?
Again today  Same deal. Power cycle corrected it. This was after calling tech support having them check things and have me manually switch to channel 11. Lasted 15 days.
Message 11 of 22
JamesGL
Master
Hi snoobler,
You can use the link I have provided for the updated firmware.
Message 12 of 22
Jsleek
So...are you saying we should downgrade to R7000 Firmware Version 1.0.9.26 - Hot Fix today?
Right now I'm using Nighthawk R7000 and I have Firmware Version V1.0.9.18_1.2.27.
Please clarify @JamesGL
Thanks.
Jordan
Message 13 of 22
JamesGL
Master
Hi Jsleek,
The latest firmware is 1.0.9.26 and not the the 1.0.9.18. You may not find it on the support page for R7000 but it has different link to download which is from NETGEAR as well.
Message 14 of 22
Jsleek
Oops! Right. It's an upgrade!
Thank you.
Message 15 of 22
JamesGL
Master
Hi Jsleek,
How's the latest firmware?
Message 16 of 22
JamesGL
Master
Hi Jsleek,
Message 17 of 22
snoobler
And again (two days ago)
Wifi is down
This was on the V1.0.9.26_10.2.31 Hot Fix
Message 18 of 22
snoobler
And again.  Same as always.
Message 19 of 22
Guru
You should review this and maybe revert back to this recommended version of FW:
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/R7000-1-0-9-26-Feedback-Thread/m-p/1520141#M...
My Setup (Cable 1Gbps/50Mbps)>CAX80 v2.1.2.1(LAG Disabled)>RBK853 v4.6.3.16(AP) & RBK752 v4.6.5.14
Additional NG HW: C7800/CM1100/CM1200CM2000, Orbi CBK40, CBR750, RBK50(v22), SXR30(v110), R7000(v34), R7800(v84), R7960P(v82), EX7500/EX7700, XR450(v120) and WNHDE111
Message 20 of 22
pkaytes
Guide
Same problem here since upgrading FW to V1.0.9.26_10.2.31...
Local devices including the R7000 are pingable.
Routers web interface stops responding regardless of using routers ip or "routerlogin.net".
All client (LAN and WIFI) DNS requests fail presuming they're using the R7000 as their DNS. If you run nslookup and override the default dns (as provided by dhcp) and point directly at your ISPs DNS servers, name resolution works which stinks of a router fw issue.
Only solution: Power cycle.
Message 21 of 22
Jsleek
Performed the latest update a few weeks ago. Much better. No issues for a few weeks straight now. Thank you.
Message 22 of 22
Top Contributors
Discussion stats
  • 21 replies
  • 1511 views
  • 1 kudo
  • 5 in conversation
Announcements
Orbi WiFi 6E
